- May 15, 2015
- 152
- Vinyl
- CircuPool Edge-25
Put up some pics of your water, let's watch the progress!
Straight6tt, please consider the following possibility and see if it lines up with your treatment timeline:
1. When you first added chlorine to the fresh water and it turned clear green, with purple ch test, you very likely had oxidized iron or copper. Algae does not turn up instantaneously from a tap.
The purple end point to me confirms metals, city water or not.
2. By not adding enough chlorine while trying to figure out the tint, it THEN turned cloudy from algae
OR it turned cloudy from the Metal Free, which might work like Metal Magic in that sequestrant CAN cause a few days of cloudiness as the metals bond to calcium that is then filtered out.
And THEN got algae from low chlorine. (do you actually see any algae?)
So...you cannot/should not treat for metals when you shock/slam, and, according to Metal Magic, you should not shock/slam a week before or a week after.
SO finish the slam, pass the OCLT, BUT if your water is still tinted (your filter might actually clear the majority of it) but CLEAR then use a larger dose of Metal Magic (which you already ordered) until the tint is gone...but remember when you use it that it can make your water cloudy for a few days, so don't turn around and immediately slam again
Another thing you might try DURING the Slam is to enhance your filtration with a Slimebag, which may "catch" some of the oxidized metals: The Slime Bag | The Easiest Way To Maintain Crystal Clear Pool Water.
Any of the metal that gets filtered out now will help down the road.
Hope that helps. Once you're sorted out, avoid needing to slam by always maintaining the cya:FC ratio -- so you don't oxidize more metal.
These questions are more for the experts than for s6tt:Straight6tt: said:
- I filled my pool 3 weeks ago and as soon as we added chlorine (bleach) the pool turned green/yellowish and it has not dissipated. Some days i can see the pool floor quite clearly other days (like today) the water is very opaque.
- I am not on a well, I have city water.
- I filled my pool with my hose with city water.
Straight6tt: said:So I thought metals again
This comment from the first post left me ... although I can't say that I've ever looked at a "tub of bleach"...Straight6tt: said:the water is very opaque. The pool looks like a greenish tub of bleach.
I guess I'm in the minority-- or possibly alone... but there's a few things I don't understand that could just be red herrings... in any case, I really wonder if everyone shouldn't rewind for a minute... so here goes:
#1
- How would a freshly-filled pool, from a city (non-well) source end up with metals in the water?
~and given that s6tt reports that there is no discoloration in his/her toilet tank, the assumption that it is iron seems especially unlikely.- And though metals might explain the water turning green (but yellow?), it is certainly NOT the cause of "opaque" water, right?
#2
- Have you had problems with metals before? If so, is your fill source this time the same as then?
- I assume that you were refilling because you changed your liner? Or is this a brand-new pool?
#3
There has been a recurring thinking that the problem must be metals in the water.
But how commonly are metals found in municipal, non-well sources?
I do know that generally, if there's a problem with iron in someone's tap water, there would be rusty, brown stains in his/her toilet tank. I don't know what other metals could be a problem in municipal water sources, or whether they stain the surfaces of toilets...
I realize I'm new to posting here, {but I'm not new to what used to be known as "BBB"}... and I don't know if my opinion means much yet. However, I have no doubt that it's possible, with all the expertise on this forum, to get to the bottom of this mystery, and have s6tt's pool in shape in no time!
