I live in Northern California and looking to rebuild/resurface an old in ground pool. The surface is currently white plaster and we're considering a colored Pebble Tek. I need information from someone other than the salesman. Does Pebble Tek last longer? If we get colored Pebble Tek, can we raise the temp of the (non-heated) pool? Is the Pebble Tek more conducive to algae growth since its not smooth? Do the pebbles (and beads) come loose?
And on that subject, what about the even more expensive Pebble Sheen? How does it hold up over time?
Thank you!
Thank you!
