@JamesW How do you test this? I have all my 1.5in piping exposed on an older pool do to a leak and want to upgrade to 2in while im at it. I thought larger is better but could the 2in actually cause me issues?As long as you keep the water velocity below 6 ft/sec on the suction and below 8 ft/sec on the pressure side of the pump, you should be fine.
If you don't need the flow, just keep the flow below 38 gpm.
- Size.......6 ft/sec......8 ft/sec.
- 1.5"...........38...............51 gpm
- 2"..............63...............84 gpm
- 2.5............90.............119 gpm
- 3.0".........138.............184 gpm
You should switch to a variable speed pump and run as slowly as possible.
Moved from here.
