I am looking to see where piping might be going, what I can expect from a 1982 installed system, how they would likely lay out the pipe. I believe there is a blockage or sand and dirt (we cleared up A LOT of muck from this pool). The main pool drain does not take water out of the pool. The skimmer does take water out of the pool.
We have been doing a lot of work, realizing there is a blockage somewhere. I am digging in the yard to try to find piping, bust in, clean, correct and hope.
We have tracked pipe from bottom drain up to skimmer, this is one of the pictures (closer up).
The overview picture shows arrows pointing out:
- Bottom drain
- skimmer, and where we tracked bottom drain line, so we can see that the pipe runs up, wall, to skimmer location
- Control, there is a control for the spa to the right of the pool, I might be digging here soon
- Pool house, the pipe coming into the pool house is to the back left, coming through the floor
I can get a sensor through the bottom drain and up to the skimmer location, maybe it is just a piping issue? Looking for suggestions! TIA
Peter
- Bottom drain
Peter
