- Jun 24, 2022
- 86
- Plaster
- Jandy Aquapure 1400
Hi all,
This post might be more appropriate on the Deep End section, but I was curious so starting here .
I test my pool water daily (sometimes twice a day lol) and it should all be available in my signature. I'm pretty diligent with most tests. FC and PH daily (since i know my ph rises quickly). Calcium and CYA less often. TA somewhere in between. (I Know my TA is a smidge high, I'm working on it, I have high TA in my fill water, and the cool nights + heater + lack of rain in the NE has lead to lots of re-filling lately).
I rarely test CC but when I do its with the 10ml measure, and if theres even a hint of pink I record 0.5 -- I doubt my CC is ever really that high, because I really have to strain to make out some pink in there. So if you see 0.5cc on a few of my test results, keep this in mind.
Went to <The store that shall not be named> to pick up some supplies today, and for giggles brought some water. They were surprisingly close on CYA and TA and PH, but they were lower on FC/CH than my taylor kit. I trust the taylor, not worried there. Was also happy to see 0.0 Iron and 0.2 copper (Which is the same levels it was at when I first filled my pool last year).
They also reported 4000 for phosphates. I know the general advice here is not to worry about them, and gather that if you're about 2500 you can treat *if you want* but its not necessary. I also know we don't *generally* trust "their" machines . Is it worth investing in the taylor kit for phosphate ? Or should I just not waste my time?
Since i always keep my FC on the high end (Aim for 6-7ish) I've never had anything BUT crystal clear water (except this past weekend when we had a pool party with about 30 kids, it was cloudy after that and FC read 2.0, but I added some liquid chlorine to boost my FC back to 7 and it cleared up in a day).
I generally tweak my SWG % a few times a week as the levels rise and fall. I've found water temperature to have a significant impact on chlorine levels. And obviously bather load (We have a lots of kids over often).
So my question is: with Phosphates THAT high is it having *any* effect on my SWG output? For example, if I were to bring Phosphates down to 0, would I *in theory* be able to lower my SWG % and give my cell a little longer life? Assuming I maintain my FC where it belongs relative to my CYA? Or phrased another way -- do super high phosphates have any effect on the rate at which FC is consumed, assuming theres no noticable algae outbreak and FC is properly maintained and CC is 0?
I know this is a "loaded question" around here, so apologies in advance. I searched on the topic and didn't see anything that specifically answered what I was getting at .
