Just to rephrase what Marty already said: The Acid Demand Test test table in the Taylor booklet doesn't consider Borates. And Poolmath probably also gets to its limits that far away from typical pool pH.
(Edit: actually, the acid demand test doesn't really bother about the borates, it's just a scaling from mini-pool to a maxi-pool.)
Assume that your pH is 8.2 and calculate with Poolmath how much acid to add to get down to 7.8 (as Marty said, don't aim for more than 0.4 reduction). Add acid, test after 30 min with pump running. Repeat until you get to 7.8-8.0. Retest TA in-between as well, as that will decrease with every acid addition and affect the required acid amounts. If your pH really is at 8.8 (Edit: I don't think your pH is that high, just want to point out what can happen in a scenario like that), then taking it down to 7.8 would reduce your TA from 80 down to nearly 30. Don't take TA below 50. Once TA is that low, I'd expect pH to drop further down on it's own by CO2 absorption from the atmosphere. Is your pool open or covered?
