- Sep 17, 2016
- 188
- Plaster
- Jandy Aquapure 1400
Hello all!
i need some opinions as to what is going on.
For the last two weeks, each time I have tested PH levels with my Taylor 2006 kit, the reading has been 7.2 or close to it. Because it was significantly lower than the day (or two) before, I re-tested it. The re-test reading was 7.8. Strange, but I chalked it up to maybe putting in 4 drops instead of 5 or maybe the drops needed shaking before?? Same thing happened the next time I tested....same results. Tested a third time on the second go around to confirm the higher reading of 7.8 was correct and it was.
Same thing happened last last night when I tested! Any idea what I may be doing to get an initial low reading each time I test PH levels?
thanks for any insight!
