hey all. i'm on my 3rd season of having a pool. been following the TFP method since the start. details of pool are in sig. for the most part things have been going well for me, have had some random incidents of water cloudiness pop up due to trying to strike the right balance of pump run time and SWG % but otherwise hadn't had a ton of issue. that being said one thing i've noticed is that my TA and PH have pretty much stayed the same for the entire 3 seasons. which i find weird since the general theme is that if you have a SWG the PH will creep up.
Every time i've measured TA its been between 110 and 130, which i chalk up to just variances in my drops when doing it. PH has also always pretty much been 7.2. I got one of those PH testers last year and whether i use that or the drops they measure the same.
I decided this past week to add some 20 Mule borax to raise the PH a bit as the kids always complain about eyes hurting. I put 1 box in (4 lbs) and confirmed it raised my PH to 7.6. fast forward a few days and i tested the water again today and my PH is back down to 7.2. i've never seen it go below that, it appears that it gets to 7.2 and just stays there. (full transparency my water is cloudy again and FC is down to 1, so it is fighting something right now). for this past week i've been running my pump from 8am to 10pm and have the SWG set to 100%.
only chemicals i've added is liquid chlorine and dry stabilizer as needed. we do have an auto cover and keep it closed overnight but generally open it during the day unless its raining then we keep it covered. pool was uncovered during the day through the weekend and monday but stayed covered yesterday as we were busy and didn't get a chance to open it.
Last full readings
FC - 1 (today)
PH - 7.2 (today)
TA - 110 (5 days ago)
CYA - 70 (5 days ago)
CH - haven't tested this year
any thoughts/suggestions on what i should do or could be doing wrong?
Thanks!
Last full readings
FC - 1 (today)
PH - 7.2 (today)
Thanks!
