Closing pool today
PH registers at 8.2
The water level in pool is low and it’s been running 24 hrs circulating slam protocol.
Due to low water level, after vacuuming to waste, the return valve has created aeration in pool.
Never thought much about it until reading Aeration creates Higher PH levels.
Questions:
-do I add water(only to turn around and drain ) into pool to stop aeration and then add MA until I get a reading of 7.2 - 7.5
-How long after adding MA can I check reading.
- does water temp effect PH reading?
Thank you
PH registers at 8.2
Questions:
Thank you
