I switched to salt this year, and pool remodel/replaster (done in March '17) reduced size to 20K gal. I am still trying to get things settled down and pH is my current problem. I am adding 16-32 oz. muriatic daily to keep it at 7.8. Posting here since it seems SWCG raises pH.
TA has been rock solid at 70 ppm. FC is finally settling down at 4.5 with IC40 set to 23% and pump running 22 hrs. at 1050 rpm, then 2 hrs at 2000 for the Polaris. CH tends to creep higher although I have never added anything. 225 up to 450. My Taylor kit currently says 425 (had a lot of rain). As a check, Leslies test says 325. My reagents may be a year or 2 old. Pool fill water measures at CH 100. My CYA test says 50-60. Leslies test says 70. Just finished adding 4 lbs. stabilizer over the last couple weeks.
Looking at recommended levels, I seem to be in ballpark. But I question the difference in my readings vs. Leslies for CH and CYA. Having to reduce pH every day is a pita.
Oh, I rarely run the bubbler/deck jets, so aeration is not likely an issue.
