Hi, I’m new here and could really use some advice. I have a 2hp pentair wisperflo that has an air leak I can’t find. It’s a dual pump system and the second pump is fine so I know the air leak has to be like right at the pump somewhere. I swapped the tops on the two pumps in case there was something I couldn’t see wrong with the one and no change. Double checked both plugs, checked the bolts on the gate valve, I can’t find it anywhere and don’t really know where else to look.
Is there a chance it’s the impeller seal?
Or if anyone has any other ideas I would much appreciate any ideas anyone has.
Thanks in advance.
Thanks in advance.
