So I just was searching the web and see there are a bit of other people with similar issues with the SWG creating chlorine at slower speeds.
For me a brief was that when the pool builder put the D.E. into our filter he poured 9lbs in however the filter says 6lbs. When I originally played with the RPM for the pool pump anything lower than 2100 RPM would turn the RED low flow light on.
About 3 weeks ago I cleaned the filter and left everything as is.
This morning I was going to clean my SWG however when I took it out it looked brand new on the inside with no calcium buildup at all. I put it back together and started the pump back up at its previously configured speed.
Then I saw nv269's post today and started to wonder if maybe my flow rate was lower due to the filter being dirty. So I just went outside and started playing with the RPM's again and watching the flowrate on my SWG.
I am pleased to say that I have now dialed it from 2100 RPM down to 1610 RPM. Quite a difference on ambient noise as well. My pressure regulator on the filter went from 11 down to 6 when I lowered the speed. I will go back out in a bit and make sure the flowrate is still good.
If I now dial it to 1600 the red flow light comes on. Prior to me cleaning the filter anything below 2100 the red flow light would come on. Lots to learn
UPDATE:
So I went back at to look at my SWG about 30 minutes after lowering it to 1610 RPM and once again the low flow light was alternating RED/GREEN. When it is RED no chlorine is being produced. I upped the RPM to 1650 and will go back out in a bit and monitor it.
What I did notice at this lower speed is that the WEIR doors in my two skimmers are no longer getting sucked to the waterline. With this said I am not sure how bigger leaves and such will make it to the skimmer. The smaller debris is passing around the sides. Something else I will need to monitor now.
