Hi everyone,
I have a solar heated pool with a “Pentair Suntouch” control panel. Recently I noticed that when I set temp lower than water temp, the Pentair shows “Water 80/70F SOL OFF”. And the Jandy Valve moves to SOL OFF position. It is great. While when I set temp higher than water temp, Pentair shows “Water 80/90F SOL ON/OFF”. It shows alternatively “SOL On” and “SOL OFF”. The Jandy Valve moves towards to SOL ON position when the panel displays “SOL ON” and the Jandy Valve stops moving when the panel displays “SOL OFF”. Eventually the Jandy Valve moved to SOL ON position.
Do I need a new Pentair Suntouch? If not, how can I fix this problem? Thanks a lot in advance if someone can help!
