We just had a new Pentair ScreenLogic system added to our existing pool system We can use ScreenLogic to connect remotely to the system but when trying to connect on the local network the app never gets past the ”Searching for system controller” message. Our pool guy and I have called Pentair support multiple times, but unfortunately the advice tends to verge on the absurd, with guidance like “The ScreenLogic Interface won’t work if you have 5GHz configured on your modem”.
Since ScreenLogic remote login works well, I’m pretty sure that the interface is wired correctly and can communicate over the modem. However my guess is that the IP subnet mask has been incorrectly configured on the interface. Our network is set up as 192.168.1.x with a 255.255.255.0 mask which might confuse the ScreenLogic which MIGHT be expecting a 255.255.0.0 mask.
So I have been trying to configure the interface but not having any luck. I installed the SLconfig application on my iPad (the same one that successfully connects remotely to the ScreenLogic app), but can’t get it to connect to anything, either locally or remotely. So I have a few questions:
1. Has anyone had this problem where you can connect remotely but not locally to ScreenLogic?
2. Is the password for the SLConfig application the same as the password for Remote login to the user app?
3. If it is, any ideas why I can’t connect to the controller using the SLConfig app?
4. If the passwords are different, any suggestions on how to reset the confpig password?
All suggestions are greatly appreciated.
Thanks
Eric
Thanks
Eric
