This year’s opening started off with a bang. The liner fell due to a warm winter, which I fixed, but there’s wrinkles at the bottom that are fairly severe I still have to attend to.
Also, it appears that DE is seeping back into my pool. I’ve tightened up everything and I don’t see what’s causing it.
But my main reason for jumping in today is that I noticed a drip from my drain plug. I tightened it up and it continued to leak. Today I replaced the plug and o ring and used Teflon tape. It went back to leaking and when I tightened it, it slowed down, but is still leaking. Old plug showed no signs of wear in the threads and o ring was intact, but I replaced anyway.
My guess is the tank drain is stripped but still m wondering if there’s an obvious visible sign if I take it apart, so I’m not buying a new tank bottom for nothing.
I did see the previous post where it was suggested to never remove a Pentair drain plug.
Any new help is appreciated.
