My Pentair Challenger Pump has sprung a leak and nothing I have done will fix it.
The leak is in the socket union that attaches to the top of the front housing. I've tried caulk and then I tried sealing it with teflon tape just as a last course, but I think I need to just replace it. The pressure just forms bubbles in the caulk which quickly rupture, and the tape did basically nothing.
My questions are, 1) what sort of sealant should I be using to shore up this leak? 2) Should I just replace the whole section? If so, will I be able to remove the union without damaging the front housing, or will I need to replace the front housing and the union?
