I think I already confirmed by searching I'm just out of luck here, but two of the three Microbrites in my pool are now unable to emit red light - there is a very, very dim red light in one of them, nothing in the other. So if the dial is set to white, blue or green they all work - set it to red you get one light and two off, set it to magenta you get one magenta and two blue. And of course nearly all of the color-change modes include red or magenta in the sequence so you lose a lot of that effect.
I don't have any automation or an Easy Touch, the 3 lights are controlled on a single Intellibrite controller. Like I said I think I know the answer but just looking to confirm, is there anything worth checking at the connections anywhere or is this an obvious failure in the lights themselves and replacement is my only option?
"Magenta" - you can see the purple hue in the lower left from the one that's working correctly:
Red:
Red:
