Hello, I have a 6 year old Pentair Mastertemp 400 that I use regularly. I have replaced the Fenwal Ignition system, the circuit board, and the touch pad in the past.
A few days ago, I stopped being able to turn the heater on through the Pentair App. I am still able to initiate the the valve change for the oumps, but the Heater touch pad turns on (all lights come on and the display reads r04) then shuts off. However, the heater cycles on fine if I press the “Spa On” button manually on the touch pad.
Any ideas are appreciated. Thank you very much.
Regards,
Doug Ingalls
Regards,
Doug Ingalls
