The display does not light up or display and codes. It had worked just fine the past couple of years with a new keypad. I ran it for 3 days while we had freezing temps, now nothing. The fuse looks good. What next?
I had a similar episode with my MT heater. Connectors were intermittent. There were random malfunctions where wiggling one would get things going again. This was a 2-year old heater with connectors looking completely fine. Finally got it to be reliable (2+ years now, knock on wood) by pulling each connector apart, spraying with CRC contact cleaner, and re-plugging.ok, yes, CB is good. So just now, I was going to test for the 24 volts from the power supply to the board, got nothing, maybe was not testing it correctly... plugged it back in and it lit up and is working now......
