Long story short pool builder didn't finish the job.
I was close to not installing the Laminars as the final thing I need to do but finally decided I'm going for it.
Along the long side of my pool I plan on doing 3 Laminars. They all have their own dedicated water pipe and electrical pipe. I will also be doing the 1 1/2" drain. Along this same run is I believe 3 Pex gas lines, 1 water line for a waterfall feature, and an electrical line for the same waterfall feature.
My question is if I can get away with stabilizing the Laminars with rebar and filling the whole area in with rock?
Or should I do a concrete base along the whole way and encase all those lines, including the drain line for the Laminars in concrete, as well as say halfway up the laminar for increased stability?
I would love to just fill with rock but I'm not sure if the vibrations of the water flow or whatever will affect the stream. I do have each laminar individually valved and a clean and clear 100 for the filtration. I'm just trying to finish up.
Again, I would love to just stabilize with rebar and wire and fill with rock. Concrete would be more laborious for me and I'm not sure if I can or should encase all the pipes in concrete.
Thank you,
Jon
Thank you,
Jon
