I experienced the exact same problem not every day, but rather whenever I open the pump to clean out the basket. I do not have a suction leak when my system remains closed but everytime I open the basket the system siphons down and the pump throws a dry alarm within about 8 seconds of startup. Fiddling with prime settings made zero difference. As mentioned by PoolEngineer I think this stems from a firmware problem with at least some Intelliflo pumps. The only workaround I could find was to disable Priming feature altogether which results in the pump running at the programmed speed i.e. does not kick up speed to max speed if it senses lack of prime. In my case my lowest set speed is adequate to still pull water and prime the pump and it doesn't throw the dry alarm. Not the ideal solution but at least it works.
