I've been surfing around the threads for some help with a couple of IntelliCenter installation questions. I'm not finding much, I suppose since they're still fairly new. Please go gentle on me. I'm not electric expert and I've seen some other people's questions on this not go over well...
- I've hooked up the wireless bridge that comes with the IntelliCenter. But when I go to the internet settings it's telling me 'No Ethernet Connection: No ethernet connection has been detected. Please verify that the cable is plugged in and try again.' I feel like maybe I'm missing something obvious? I've included a picture of the error and wiring for the module.
- I'm adding an IntelliValve to the gate-valve that controls the flow of my automatic debris removal system. It's a good distance from the equipment pad/shed, and the built-in chord for the valve doesn't reach. The total distance is approx. 30-35 feet. What's the best way to lengthen the cable? Order another IntelliValve cable and splice them together? Also, should I bury the cable inside an electrical PVC pipe, or is it ok to bury it on its own (obvious potential of breakage down the line)?
So far that's all I have. It has been quite the series of trial and error. Being as safe as I can! Everything is bonded and grounded. Completely screwed up drilling the hole into the pipe for the IntellipH. Heading to Lowe's now based on someone's suggestion to use a tee connector and bushing that the IntellipH can screw directly into instead of having to use the provided clamp. Otherwise, the system has been running beautifully for about a week now! I'll post pics of the system once I'm completely done.
