Pentair I40 in diagnostics shows red for cold water and no salt level
dweller
1
Hurst TX
Need a little help, my I40 is not producing chlorine and in diagnostics mode has a red cold water light and reads 0ppm on salt, pool salt level is about 4000, is this a sensor issue because shows the cell life is about 40% used the cell is a 2018 model flow switch has been changed also.
D,
Most cells last 5 to 7 years...
The "life left" is more just a guess and really means nothing in the big picture.
When in the normal mode, what does the Cell light do? If it is blinking and the cell is clean, then the cell is dead.
As a test, set the cell's output to 50% and watch the cell light.. It should on for about 2.5 minutes and then off for about 2.5 minutes.. This will just keep repeating.. If this works, then most likely the cell is making chlorine, but your pool is consuming it faster than your cell can make it.
What color is your water???
What is your CYA level??
What FC level do you normally try to maintain?
