Pentair Home app: how to turn on superchlorinate?
soleen
Active member
May 17, 2023
27
New Hampshire, USA
Pentair Intellichlor IC-40
I see options to setup time for superchlorinate, but I can't find how to turn it on. Anyone found it?Screenshot_20240426-194642.pngScreenshot_20240426-194618.png
I am no good with automation, so apologies that we have to wait. While we wait, can we discuss superchlorinate ? Are you aware what it does ? It just bumps the cell to 100%. You might as well just bump the cell to 100% yourself. People often attempt to use it to fix troubles, and that's not what it's for.
Reactions: Bperry
Currently activating/deactivating super chlorinate does not work from the Pentair Home App. However, I never use it. I just dump in liquid chlorine when/if needed. It also raises FC faster.
Reactions: soleen
Thank you, so the app is basically incomplete, do you know of this is a known issue or should it be reported?
Anyways, I am actually using home assistant integration, which surprisingly still works even after the pentair app change.
