I have had this filter since 2011 and the past couple of times when removing the ring clamp I had a hard time sliding the long bolt out of the sleeve. A closer look shows that the bolt bent a little due to the design of the spring and barrel nut. With the bolt no longer being straight it’s hard to slide along the sleeve.
The poor design is As you tighten the barrel nut the spring and washer move closer to the ring clamp body and push against It creating an outward force acting on the bolt. The more you tighten it the more outward force it puts on the bolt and bend it. I tried not to tighten it too far in to avoid the problem but it caused a leak. I guess I can go to the hardware store to at least to find a small washer but don’t know what to do with the spring. I am just curious if anyone else have the same problem. I’d noticed this flaw the first day installing the filter but not until recently it bent the bolt. See pic below for better explanation.
Thx
Thx
