I probably used this stuff. The 18/4. The smaller 22/4 is a little cheaper.
Ethernet cable would work, too, if its rating fits the usage.
I eliminated all the Pentair wireless stuff and hardwired everything. You can use a star topology, or daisy chain devices. The bus is pretty forgivng in that way. I have multiple devices connected to the same mother board connector (that's the star topology), but one run connects from my EasyTouch to my ScreenLogic adapter, a few rooms away. From their I ran a wire to my indoor controller, so that's the daisy chain. Not everything has to run back to the main controller individually.
The advantage of using the wireless is a bit of isolation should a lightening strike take out your IntelliCenter. Things on the other side of the wireless bridge might survive something like that. I think
@Jimrahbe has had some experience with that. But I hate wireless and like to live on the wild side.
For my connections at the mother board, wherever I needed to stuff more than one wire into a connector, I soldered them together first. This makes subsequent "uncoupling" more difficult, but I do that to help eliminate the corrosion that can lead to buss problems.
Another trick is to solder all the wires together with a tail, and then use only the tail to connect to the motherboard. Jamming too many wires into the connector can also cause a problem, like if one wiggles loose.
Those kind of steps are mostly unnecessary, but I like to build to last, and soldering has always been my MO for that. Probably just me...
Alternately, you can connect some things to the motherboard, and other things to other connectors that you might have on the same buss. Pentair's surge board for their IntellliChlors has additional buss connectors. You can use those, too, if you have too many wires at the motherboard.
