It is for 9k gallon fiberglass in ground. (Salt). We do run it year round. I have split running times to twice daily for 8 hrs each. Before you could feel the warm water through the discharge. Currently is about the same temp as the pool, even though yesterday it said it raised it by 4 degrees after all day. Normally I get about a degree an hour change. I usually keep it about 94 here in TN in the winter, with a solar cover. My pump is 1 3/4 continuous I’m not sure on exact gph discharge. (X2) This heater was plug and play, just now has become a nightmare. Replaced manifold and sensors, new membrane and circuit board, only thing left is stack flu and ags. I have hit the buttons on the membrane pad and it reads within the limits in the exhaust. I did run a little endoscope as much as I could into the coils, the do not look bad internally. I’ve always kept my water pretty darn good since I’m retired. As you can see. I have dumped about all I can into this unit. For myself I know things can’t run forever, but 3 yrs to go to heck? That’s about 500 bucks additional heat expense per yr.
