For sure go with a 400 btu heater and do it right from the begining... The cost difference for me between the two heaters is $227.38.. I don't even offer my customers anything but 400 btu heater..
Ranger987 said:If the ultimate goal is fastest possible heat time and money is no object then why didn't you purchase the Hi-E2? It's 95% efficient! You'll probably be in the spa 15 minutes quicker! Oh, but it does cost $6000.00 - apparently, even for you, cost does come into play at some point.
Keven said:For sure go with a 400 btu heater and do it right from the begining... The cost difference for me between the two heater is $227.38.. I don't even offer my customers anything but 400 btu heater..
mschmidt33 said:No spa guys... "The smallest pump I use is a 1.5 HP pump. It's only $30.00 more then a 1 HP but turns a lot more water and does not use much more energy." This was from an email from our PB.
mas985 said:Also, I understand that you don't have a spa but I had assumed that the heater was for augmenting the heat since you were going with solar. So do you plan to use the heater only when solar is not producing enough heat during colder weather? You may find out that it isn't worth the cost to do so.
mschmidt33 said:Since I have never owned a pool I'm not too sure... I believe at this time the only time we will use the gas heater is to keep the pool warm in the spring and fall when solar is not effective enough to keep the pool at the temp we want.
mschmidt33 said:A 2 speed is in the contract as cost neutral.. Tristar or Northstar or equivalent... my choice. ~$350 upgrade to VS and ~$300 savings for 1 speed. What to do guys?
mas985 said:mschmidt33 said:A 2 speed is in the contract as cost neutral.. Tristar or Northstar or equivalent... my choice. ~$350 upgrade to VS and ~$300 savings for 1 speed. What to do guys?
You will get that back in savings in a year or two so yes, definitely go with the VS. Hayward also has the ecoStar which is their newest VS but there isn't much history yet.
