I'm installing a Latham Rockwood oval pool - according to the manual it must be installed at least 14 inches below grade. I've dug two test holes in my yard. I get water at 14 inches in the lower portion of my yard and at 27 inches in the higher portion. (The pool will go from the higher to lower portion.) I assume this is a problem. What are my options? I was thinking of digging deeper than 14 inches and putting gravel and drainage pipe to move the water away from the pool.
Any advice would be much appreciated.
