Need some advice regarding pumps/plumbing with an in-floor cleaning system. Pool was completed September of last year, and I don't like how they have the plumbing set up.
Our pool is ~900 sqft and 33,000 gallons. We have 2 Paramount ParaskimV venturi skimmers and the Paramount PV3 in-floor automatic cleaner. Pump is a Jandy ePump 2.2. Filter is a Jandy CL 580 cartridge.
Since opening the pool a few weeks ago, I've notice that the in-floor has some dead spots that don't get clean and just accumulate dirt. That got me looking at the manuals and searching for answers.
The pressure gauge on the in-floor is showing ~10 psi when I have the pump running at max and 100% of flow directed to the in-floor. That's maximum pressure I can get to the in floor. Per the manual and a conversation with Paramount this should be 17-22 psi. I'm showing 20 PSI at the cartridge filter, but that doesn't maintain all the way to the in-floor returns valve.
The second issue I have is they builder didn't connect suction to the skimmers. I know they are designed to run venturi only, but feel like they would be more effective if they had the suction connected as well. We weren't presented with this as an option during construction so didn't know what we were missing until it was too late. Additionally, since suction isn't connected to the skimmers, they aren't running if I'm maximizing pressure to the in-floor and I have no way to vacuum the pool if I wanted to.
I'm hoping there is a way to connect the suction to the skimmers without too much disruption. Is this even a possibility at this point?
What other alternatives are there to increase pressure on the in-floor?
What other information do you need to make recommendations??
I'm going to give the builder a call, but given how the system they just built is functioning, I don't have a ton of faith in them. Looking to arm myself with your collective wisdom so I can have a better discussion with them on how to fix the issues.
