I have a paramount in floor cleaner that came with the house. I have two separate zones each with its own booster pump. I have replaced both 6 port module twice. The pressure does not stay at 20 it drops to 0. The system used to maintain pressure then switch ports. My filter pressure stays around 20 and I have directed valve to only the In floor cleaner and the main drain. It’s almost like the pump will not prime but I have filled them with water and both start then pressure goes down. Any suggestions?
