I have a 24,000 gallon heated, indoor, gunite, commercial pool currently sanitized with bromine tabs via an offline feeder. It has been brought to my attention by several of the experts here that using bromine tabs over time causes a build-up of DMH which reduces the effectiveness of the bromine over time. Also, since we are regulated by the state (Massachusetts) it is my understanding that I am not allowed to have any CYA in an indoor commercial pool (however I trying to find more clarification on this). Traditionally I have not had any and I am changing the water in a few weeks and now would be a good time if I was to change from bromine to something else.
I have been trying to find a different way to sanitize and have explored SWCG and liquid chlorine/acid ORP/pH systems, but I am hesitant to go with SWCG for my indoor pool. If I stayed with bromine I would be interested in not using the tabs if possible and read somewhere in TFP that ozone might be a helpful secondary sanitizer for indoor bromine pools? We have a high bather load and I am trying to ease the management as well as the build-up of CC over time that we experience after several months. We typically change the water annually due to this.
I was told to just add straight bromine until the water reaches the desired level and then just use liquid chlorine to avoid DMH build-up over time? If that is the case would and ORP for liquid chlorine make sense as well? I was thinking the ozone to help with reducing chloramines at the very least. Any suggestions would be appreciated.
Darin
24,000 gallon indoor gunite pool 92 degrees
offline brominator
hayward tristar VS 1.85hp pump
hayward pro-series 500lb HR sand filter
Raypack 333k natural gas heater
Darin
offline brominator
