owner build - suspended pool infinity edge
A small suggestion if I may, the intelliflo pumps are great pumps however they need to be protected from power surges, lightning strikes etc. As you know T&Tec supplies terrible power with frequent power cut offs and power surging. I would suggest investing in a line conditioner/ power surge protector to protect your pool equipment.
Hi maria, thanks for the tip on the photobucket - will check it out. I've added some before photos for you in the mean time
For this I'll be using variable intelliflos, ic40 (volume is less than 12000 gallons), 24" sand filter and another intelliph to inject acid....I've had good experiences with that setup in the past.
This build is in the s. caribbean...TT.
Thanks for the tip. Additionally, as far as those VS pumps go, which I do intend to use, I've read of numerous amazon reviews where the electronic board went bad. I already got some of this which I intend to experiment with in terms of increasing its longevity from moisture damage.
Hope it works.
the tiling is just about done.
here's the 'custom' skimmer
almost ended up perfect...
the trough tiling went down 16"...
and finally, the coping, waterline and shelf tiling all grouted.
next update likely will be the equipment room.
I should finish the equipment install tomorrow. And then the diy is practically over save for the led lights install since I have lined up to hire a team to do the diamond brite install.
The equipment list (some of which you see in the photos) includes
intelliflo VSF
Ichlor 30
Intelliph
425 sf cartridge
Hayward 50k btu heat pump
Kaplan valves (from amz)
55w LEDs (taking a chance with this China import)... I figure with the eventual failure I had before with the colorlogics, at a quarter the price it it lasts the same length of time I'm good.
Had a bit of a set back in august. There was a pretty wicked earthquake. Darn thing put a hairline crack in an unfilled pool shell with 8" poured RC walls!! So before the diamond brite I will layer in fosroc waterproofing product.
So here's the finished product.
Got some engraved labels...
Ag0gdqyBISa512b65x6F84A0UrtiqbqLq6HeQqv3nVlu1CfkqcCmXrsXqMu00Lxq8ecLXkkzHP1kY0AMBxNC1-bXChHIPdwZduFgvPN_FoS3-Q9P4_VqV5fP8NUdbZ_wwD77MzlasgB1SkRAb_1LDsz5vdp2jP0M9AGXTVB4-PWOy1OuOUhyoicIhL87lzyjRkFKBU2_N2p8umqNrYBBaFEHw56jhnlWWlSl8PdbnMZ6Uw5ylnOwrU5qhCkRtiAD942Z4qT0QZ5aLU0OZhQyLueBE8QWfvViq3yhIdmmKYQ3rmuPyPa-DyYysSPc44nso9XrWtiw3uR3XEvyElNPNFXVySr0Q0FxR5pYwMCMLG9T3StdhZ2E3VXtwKoRfAIBuoeu2hIzbrSh8vAoWWCo5cJ-Z9QWKVGa3gqRKytH4rcMS1zfAyH3e5eVvKxumyJDJgYMhPDqexxiY32A0Okl0Z-9fR2JzPMrbH9_RYMeq2WaBFkrcxKZouyDT5CfO_GvownGW3zs4v_-P3QU5LnDCvCKnhsWN8-5xOZ4A5mChzI2q5cQ95cvVvpBQN7YvdcSPz9VztzSfh48yFViPR30oR296LIswMbsp6YiWYrvq7V7Qc_APSZVlKdQJ_zipcafUzhasJoO-dSYxOm89wMtJ5fwjg=w1721-h968-no
With regards to use of unions I would have used a high temp union if it were locally available for the pump ports but in that case I share the view of some others to simply leave room so that after the first cut, unions can be placed in afterwards
LY6aHpdqgeDXkt3wYhOW0xpNVwmhKO8gT3gs5w_0t_H8SQNIzqLmJkZU6IwBEO62bFMdh6iz-OrZFVjQpScCeAY1fFmG2OfCV_PQ4PNl8PEtjp9E5F8iEciu8dHPYLfm58w9xxpBvR7chtwEGDmMdLG8R9r-eW_iCFwxghT8llDKDVqwX7uSBt9e3An3wNQc6o-BzFtt2p3e9LQoOjrjVZp21zZtOcGjAB1uXsNYyLjiyAEJ4nfaTolGGhClWwJQBTDOcbDaBx1YaRKNDPwPEyyFWDy9WC6e-ZFu2_EJV5MCcPV9LmUYzJSDjqsRcQ1Ll6WDMvoVLeOc6BJqArW3N3y8-LfnMnPJlNbYNGbTKqmnJF-0_8v0nDfq2tyL00DoD7exdwqttULF1gZs6F9cOCVS750EGepsk0KdpQD0BxLn2V13kJc3P1tbymnzInb41ayvky_WUAmRuTlDSj-nNP6-FhtkMaRSuOyznqzS_EhRTgzfb7Qtbf5i959CFwM0hgDZm-NRNSFE9Wg9uIlwgj_LaH5P9sGxs63-vs9nc0ElBgqvNUoQitnlWTh2kto16Bts5FREmfONpJtnKLGhWxYgjCUPlqU4_6gIKh9u-roXgG5fQx0_s9e5CeyneVcOf-cnAkTaaGN_hPEVm7I4JFb3Eg=w1721-h968-no
Used some rubber mounts and hilti straps to support the pipes that were offset from the wall
yuXgJCWIgHapz2hrjBJZyLJ-q-WgfongjYGSFnNKxiPuNqm4Lak5wfvJrjy7pHqOgQyXf_QCJLJO6gcfaD73u9wt9sCTJS5MTlWEM03q7_h7AdFELBOR3bwMUYgkIslBwqRN5ygvC3isjl4Hzvq5bbveKds7lForbi82de003pMjFbGgfYL9DmDGKtT3FLf_6LCxxqSL8cWrU54QBKOCjic-n9lGO8E-wsdxOQM641-wTiineQ0EcK3hgk1WSepte887czpKZwYUGVq_9FxEKA1YsC0H2j7pVXyHPNBpudMUtfyYCDYm9pr-VVNHmmtxkYiQY488Zmzt4g_J5xE_ghPJ7QL22U_rqZoviqdo6BQVOizuYB8h37hnjGjG328-zWLN4rnzfzIxaPNzlGZMsFDGFDntyx9dGOzXvgdmJ1JH8Bm4ztnVGi6nn0p5wdC9g2nF63rAPPwNJksSj4-l0omLTsxb6r42A_GM3BxFHgk1krZ-oIx_UiHVc8f_LiP-1dnv88TzwdsQRBGJK3KiJLaXNo-b8EzCx1c5I7xa5Jo6LCWd4pIWnl15lXGfCriedhzengX3JfDA9A3x2u6PWfFsIKmjZODNduzgw0xjtAQybJw-Wgv8NyM8U6OodvmicJsyvnptKFVXoGUtTojQX7gbDg=w1721-h968-no
I am yet to attach the bonding wire to the metal components (pentair power box, heat pump and water pump)
Wt7eeKtw3Q-nVL_3sJhx68GUGuovXuJ-De2fGDXveJ_1TWEaoTPlym0LeDPC7Vfx0P2b4TwRW3tld8eZTNh_SgqJmfZsARkS4vg_86owJ9YN5B3m29JOtaa8ui6RNM29HfzIJv8XbYmYGO64pmCpZbh4MSfjVnLNz5gdClVPA-xlatwaFmhROl9WbDB9p3jKFNIpuKll4n6HiVS4HTb3FWoEBAfmScpqzqJLIf9nKQvtSVXVMCh_MDp8vi-Ymlgt1eXbuonTO7wURtHQsY4eCqu1ljbliqDklCqoog1OEiOVfj7f3ALlW3vMzOLmt5y-K6qj2ppfqL3Xxg4Ygi68EuMv-mx02OO4QUFrJpRoAWh88S8JVEWrwhQaPktsxA65ToXtxeMB62alFTw4KFObjTr4D4289BLi-pxbDZ864PXlkTATX6UNfHKCUuJyr7eGCQ2sTZxX3t47OzhSfRwLnMHMizBqe8rYfWEyUBoG90-9cR4394DFUIPPwwSbi1ckUeIDHMEf1HD0Gi9SR-EQv8HU2XeoonmvikS9_XXBzBn3rvL07MiTAeb3wDx8G0iOodgGmNNiptfXBoftIJwraH3dmWeFb6N9EeVLMIt2HIQYjpmlZKhxNnn5zRpb3x8onGoalotUyczUBsq1kah2MxiKMg=w1721-h968-no
8gThwiaImG10orMDmIJqKStXDivD0DwdtiJBjVTPlr1S4amZHMp0G3DhjIfmjLECoah6HuLmWR3VIG0VUOpDvONIfxWAb6qgDQ7d2yLNeNm4GS367CbsniKENjpELfGdfCLp4G0FiXkd9O7pgpsl4982RIqxr8WTn7V6wJPvJaq2Q5Iea2_J0IfcoJfgBmrzrRClCVG8izabGnUUhZm5D5XU2AS6eydWTQTp7SqK2BRQC33QZAOVTYT84uQEELKSNPqheEhPs_tgKDQxhg8YbJYd9in-XV4tFsdimMAoQEZo5OCdCDzQs6IjhDRupqm_M-LDBmIqrunXX649ZXdKYkF7OnnJ5XwksPbGJw9YPoynWSyDxoN8Qcww9WXhMwcO3GUmeGuLbcHx5DO3E9jM8t7Jrrvej3MR-lDcEu8Vu-236SVomEzxVMA8C0C7RpKNO9whGQkAhcxKQYjIQIl2TGPJVsrgORrSmPLRJSE0U69JYGYTf6cj_-KPfFTMlrQDeQGL6EnjnQrGt5rHbwVJQbR0WYE5eRw6Og8gvxHw3f9uPDp5imoTQTtGs4-PjwKOrRqCo-WR1g2Lhh85COx_OI3HWp6jTCyd8kfk7dePOp_CDmTVy7vqUDFKivo3noWvFWhTgdPBhugSTsAgtModc2ZfesRgDG81LpJsiHAdbAntxvSgKGuk-k7_7jgCSWSmT7tgvHCZTwj_3ZOn9zM=w1721-h968-no
well no build thread is complete without the finished pic so here it is! Just got things in balance water-wise. still waiting out some more time to splice in the SWG and bring it online.
The edge ended up reasonably well for a first time, 30gpm keeps it nice and wet with a pleasing sound into the trough. this is a one pump pool -- I had read numerous builds where they had an edge pump but I didn't think I needed to go that route for my needs.
au2BwO86RT6PkyXOjZRNMEVBCQylfp4omAS5d3crHzc9Q-YXuPEmelstJHRQx43UyXRpMOftRiXuLHXoGS3QmhSBV7D7FipQMrZKx6NQ1pXyZ1qZDhP6HwIWx63jMpdAmbOHdGFQPv0k-7JQSoo1SChsmSlbq1M8jqaLY2FPrOj2do-Ddcj24WLxke60b53y4ypcIIt4grmzDhkB8az7whJBpruTDoh0ofX1GJHdiXMrmGyxDPgWYWD6dElrwhA1yhT8cPWIIpUWbMz5EO3ghZeWzwWa-V4j-ZquNgv4a_20glFrXQEu5nBXN_IF41xKG7tX9qKNLmA-LJ98hbDcoem8_Csn5QOPyR7zpnArFc2RBeGWZ9za8v9rzel3qwk_rknRAdQIvQhDkjHC61xnMK7HgSG0S_WPsd66wA-EY_9nUHJM7X77gG7aES8PB9v7mw3103jS1u--chDYhb_WyAcrqqt9M9jFAXVdEf-tb4JSaMchlp08G3CFcW8pS_l_jrjEZ0xFfR9mnaHBncvZ4muJhl017COLU_6Kem68_bPynsLSD44gXvgeZnlsH8t8muUj9L2i2Kr7r6jWcHmnHCleiWdtAl16-URCJ6_cPpSNr6WBQ7Kz9KGmyKtrPdFWsEK6R5rqKJHQWpvvezWXe8-m3xxkqqbQ=w1168-h657-no
Reactions: kimmielea
Was a watertight or damp proofing agent added to interior of catch basin shell? Just curious
I took a sort of shotgun approach with the waterproofing, I used a product that was sprayed onto the raw concrete called Radcon 7 and prior to diamondbrite application, I used a cementitious waterproofing product from Mapei....all over the pool shell and the catch basin.
The top 85% of the catch basin is tiled.
