I just bought a house with a pool and spa, and the total size is 10,000 gallons. My Pentair LPG heater is oversized when I just heat the spa. It is rated at 400,000 BTU/hour and requires a very high flow to avoid tripping the low water flow switch. But the burner cycles on and off every few minutes due to high heat exchanger temperature. Is there a way to derate the burner?
