Hi guys,
I’m located in Southern California. I’m building a 37’x16’x4’ deep rectangle pool with a 5’x7’ hot tub on the inside corner. I’ve subbed out the work and will begin excavating Monday.
Here are my estimated costs so far:
Excavation: $2900
Rebar: $4600
Plumbing (includes light and electrical run): $7000
Shotcrete: $5500
Pebble sheen: $8500
I’m planning on doing coping and decking myself.
Here are my questions:
How much deeper should I dig my pool than what my final water height will be (4’)? I assume the water level is about 4” lower than coping, and the shotcrete is 6” thick, so should I aim for a 4’10” deep excavation?
Is it ideal to have pool and hot tub on same pump? Although I’m in a warm climate I worry that the filtered water will come in significantly cooler and require a lot more heating.
Is pool tile required? I’ve never liked the look of pool tile and have heard of people omitting the tile and liking the results.
Is coping something I should diy? I’m very handy and have done all of my brick decking, bathroom floor/shower tiling etc. this is something I feel I should be comfortable with, but what are your guys’ thoughts? Quotes seem very high at 6-9k for just coping. I should be able to spend only around 1k and a weekend if I diy.
Lastly, thoughts on main drain for this size pool and my climate? My plumber says it’s necessary and there doesn’t seem to be a general consensus online.
Thanks!! Tim
Excavation: $2900
Rebar: $4600
Shotcrete: $5500
Pebble sheen: $8500
Thanks!! Tim
