Hi Allmar, and welcome. In the interest of troubleshooting, I just want to check a few things:
1. When you replaced the sand, specifically what sand and brand did you use?
2. Your sand filter is a bit smaller than mine (a 220t) but mine cleared a spring foreclosure swamp 4 years ago in 12 days...BUT it was cold, so I had a running start on the algae
As such, what is your "baseline" psi? And you're only backwashing at 25% over, right, then running rinse cycle for 15-30 seconds to settle the sand? And you're running on filter, not recirculate, right?
3. How many times a day are you dosing your FC, and is it EVER below Slam level when you dose? You don't want to let it drop below Slam level at all, so target a bit higher if there are several hours between dosing, or algae in heat can still outpace you
4. I didn't see your CH reading anywhere. Please post when able.
5. Suggestion...post pcs on steps for the next 3 days. Also hold a white piece of fabirc in front of a return to see if particulate is coming back out of the filter.
If there's no improvement at all in clarity in the next 3 days AND IF YOU PASS an OCLT, you may need to take a few uncommon swamp recovery steps -- either extra filtration from something like a Slimebag (
The Slime Bag | The Easiest Way To Maintain Crystal Clear Pool Water. ) OR possibly a very careful floc ONLY IF you pass the Overnight Chlorine Loss Test first.
The latter is usually not recommended unless its clear a Slam is truly otherwise complete but there is still particulate too fine to filter. I personally don't think your slam is compete, though you're getting closer
BTW, while I suspect you will later need to address metals with sequestrant, same will not cloud, and you must first finish the slam because sequestrant doesn't work right in high FC. More on that later after progress
Hang n there -- you'll nail it! Cheers to clear!
