- Jun 30, 2017
- 365
- Fiberglass
- Pentair Intellichlor IC-40
Would someone kindly confirm my order of operations for pool closing (@Newdude has also offered plenty of help that I have already skimmed)?
First time closer, and for some reason, oddly nervous.
- Day before close, bring up LC to about 15ppm, add polyquat 60 according to directions (allowing pump to circulate water overnight).
- Vacuum pool and sun ledge area, as needed, and remove robot.
- Turn MPV to waste and remove some of the QUAD DE debris. Run a few rinse cycles to stir up filter and then run some more water to waste. This removes a bulk of the garbage and old DE (so as to NOT make a DE mess around equipment pad).
- Turn MPV to recirculate.
- Filter is now ready for disassembly and full clean.
- Remove eyeball fittings.
- Turn pump off and attach modified cyclone blower lid to pump.
- Place gizmo in skimmer and remove top rubber plug.
- Turn Pentair diverter valve to 50% main drains/50% skimmer and blow out. This should push plenty of air through entire system (both suction and supply). As this is happening (ensuring plenty of air to flow through), plug return lines in pool.
- Turn diverter valve to 100% main drain. Once plenty of air is moving, turn diverter to 100% skimmer, which will air-lock the main drains.
- Allow air to blow through skimmer. Once done, shut off cyclone blower.
- All plumbing should not be done.
- Add gallon of RV antifreeze through gizmo hole and then plug the gizmo.
- Place MPV on winter setting.
- Pull equipment drain plugs (heater and pump)
- Turn off heater gas supply valve.
- Clean out filters, filter housing and pull filter drain.
- Store all plugs, fittings and filter gauge in pump basket and put in garage.
- Cover pool
- Place cover pumps and run electric cords.
- Drink eagle rare and enjoy one of my padron maduro family 80th reserves.
