Hello!
Can you please confirm if this is the right approach to designing the plumbing runs for a spa:
Run#1 (Filter/Heater) = suction from low wall, connected to skimmer, running back to pump, to filter, to heater, through SWCG, back to spa low wall. At the pad, this is 1 line from spa, and 1 line back to spa. All 2" pipe.
Run#2 (Jets) = suction from floor (dual "main drain"), running back to pump, out to spa jets on a loop. At the pad, this is 1 line from spa, and 1 line back to spa. All 3" pipe.
Run#3 (Blower) = running from heated blower at the pad out to looped spa return jets. At the pad, this is 1 line back to spa. All 2" pipe (hartford loop at pad).
Run#4 (infinity edge) = suction (dual "main drain") from catchment pool, running back to pump, back to spa low wall.
Run#5 (Waterfall) = suction from low wall (dual?) or from catchment pool, running to pump, out to waterfall, which flows back into the spa or the catchment pool. This is one line from spa or catchment pool. 2" pipe.
Thanks for your input!
