I was needing help on Opening, but not totally opening.....
I filled my 14000gal above ground with about 50% city water. I left the cover ON, Yes I peeked under, and it was Very clean.
I added 1 Gal of 12% Chlorine. Ran the pump for two days.
I didn't remove the cover because I will be on vacation May 27 to June 15 (19-20 days) and it will be sitting with no intervention. My thoughts are that the Cover will protect for debris and the Chlorine eating sun. My test with a TF-100 kit today has these results.
FC=11.5 CC=2 TC=13.5 TA=170 CH=350 CYA=25 PH=7.8 Temp=54F
Any guidance for how I should proceed? Should I leave the cover ON, and add a gallon of 12% chlorine when I leave on the 27th, then see what I have when I return?
I assume I should run the pump a few hours per day?
Help me get it right.
