Hi I just opened my (supposed 10k gallon) pool in oklahoma and I just can't seem to get any chlorine reading after shocking every other day for the past week-2 weeks. Here are my readings from leslies.
this is my readings after triple cal hypo shocking the night before.
FC- .17
TC- .17
PH- 7.5
alkalinity- 103ppm
calcium hardness- 265
CYA- 31ppm
iron- .1
copper- .5
phosphates 0
TDS- 0
So you can see my free chlorine and total matches which is a good thing but still low FC. Now this is my Free Chlorine and Total Chlorine reading after shocking with 2 bags of cal hypo after an hour from shocking.
FC- .63
TC- 2.91.
You can see after adding shock that it is reacting in the water and I'm getting chloramines but it disappears after 3-4 hours. I have used 13 bags of cal hypo shock over the past 2 weeks and I have been zeroing out on both total and free chlorine after 4 hours. I've been trying to do the slam method but I hate throwing money away from shocking and getting nothing. My pool is green but clear so Idk if its algae or the copper causing it green.. I have been trying to use a non chlorine oxidizer shock to get rid of chloramines but it doesn't seem to help. I am desperate in trying to get a free chlorine reading. I have 2 tabs of trichlor 3inch tablets running in my chlorinator, I have 2 tablets floating in the water. I have a nature2 copper algaecide going (which I assume is for my high copper reading), I have water boatmen in my pool. I dumped a gallon of clorox algaecide + clarifier poly (Poly ethylene dichloride). I don't know what to do. only thing I can think of is try using leslie's chlor brite 4x1lb bags and seeing if that will help or just getting 4-5 gallons of bleach and try one last super bombing of the water. Can I shock with liquid bleach in the afternoon then use di chlor shock (chlor brite) later that night? need help thanks
FC- .17
TC- .17
PH- 7.5
alkalinity- 103ppm
CYA- 31ppm
iron- .1
copper- .5
phosphates 0
TDS- 0
FC- .63
TC- 2.91.
