Opened pool, it’s a green swamp
PammyB
71
Hudson, Quebec
Hello,
I opened my pool, it’s a green swamp , I removed as much debris as I could see ( lots of leaves and branches, very stormy winter) . My question is what should I add to start
TA is 40
PH is 7.0
(Chlorine is 0)
Can I just add liquid chlorine and turn pump on to get things started then retest everything once it’s cleared up a bit and proceed ?
Follow the protocol to check for Ammonia as described in the article. If you have it, eliminate it first. If you do not, then raise your CYA to 30 and follow the SLAM Process
