Hi all,
My pool company opened my pool this year and did everything but hook up my SWG and turn the pump on. Not their fault, we just moved a bunch of stuff out of my garage and i could not find the salt cell. I finally found it (after they left of course). All i had to do was screw in the salt cell and plug in the pump -- they had done everything else (taken off the cover, pumped out water, put cartridge filter together, connected pump to the plumbing).
I have a hayward OmniLogic system to control the pool with a hayward Tristar VS 900 pump. This has been the system for the last two years and worked without a problem. The VS pump was installed by my pool company 2 years ago and last year i had an electrician and pool company jointly install the OL system. It was all working fine last year.
However, this year after plugging in the pump and turning on the breakers, the omnilogic says 'priming' but the pump doesn't turn on
I am going to measure the voltage at the outlet for the pump, just to verify it's actually getting power.
