I just purchased an older home in Florida and trying to get the pool sorted out. The pool light is not working so pulled it to the surface. Found it had been spliced at the light with the original cable being about the size of a garden hose spiced to a newer 12 volt Hayward light. I want to replace the light with a newer multi color LED. Problem is the power cable seems to be sealed to the back of the niche. Is the common in older pools? Is my only option an underwater splice with a 12 volt light? The pool was probably built around the time of the home in 1970s.
