I started the process to close my inground pool. I was letting the water drop with out adding any to keep the skimmer functioning. I decided to vacuum today and that was going fine. I was able to put the vacuum hose into the skimmer, I had a hose running in the skimmer to make sure it maintained good suction. All went well, finished vacuuming and got everything ready to back wash when I noticed that the motor and pump were running but there was no water going through the filter and back into the pool. Zero pressure. I shut everything off for a while and turned the pump back on and it was running but no water was going through the pump and filter. I had turned off the skimmer valve off because the water level was too low to keep the skimmer running without sucking air. I have been doing this for several days and just using the main drain to filter the pool water. Any way, with the skimmer valve turned off it would start pulling water from the skimmer until it would start sucking air because the water level was not high enough to keep it filled up. It is scaring me because the valve is turned off but the pump is still trying to pull water from the skimmer line. There is no water coming from the main drain at all. It was working fine until I finished vacuuming and then it just stopped. Any ideas?
