It’s not often I join new forums but there’s a real wealth of knowledge here! I’m on my third year of living in a home that came with an old hybrid pool in less than great shape.
My better half and I have a young child, so this year care of the pool fell to me. Historicity, someone used the pool place for their “sage” advice. Last summer our young kiddo took priority and the pool got away from us a bit, causing algae to form.
Upon opening this year the algae was back in spades! I skimmed off what I could, better the bottom to the best of my ability and put my Zodiac G3 to work. A couple of 15 hour days later, and nearly 12 filter cleanings later the pool was looking much better.
I’m elbows deep in to slamming the pool currently but am struggling to make headway. I found this site a few days ago and had been relying on YouTube to “super chlorinate” my pool. Thus far the pool has been laughing at my attempts.
Starting out the pool, aside from being green and very dirty was also terribly acidic. I have a re-agent kit from Leslie’s and could not register a proper PH. 12 pounds of baking soda got me to 7.2 which is when I first super chlorinated the pool. I started by adding 13 pounds of cal-hypo, since I’ve learned that wasn’t such a great thing to do when I tested CH, which led me to this site and using liquid after the initial 13 bags of Cal-Hypo.
As it stands now:
PH: 7.4
TA: 110
Chlorine: 4
CC: .5
CH: 470
CYA: 60 (I was trying for 50 but overshot a bit)
Taken from test strips:
TDS: 1500
Nitrates: 10PPM
Nitrites: 0
A phosphate re-agent test kit from Taylor is arriving tomorrow.
My Dolphin robot is running around 7.5 hours a day. The pool has been getting brushed at least once per day, usually twice. Pool is non converted, surrounded by large mature deciduous trees, gets lot of sun and does not have a cover.
I know I’m going to be starting a formal slam tomorrow. Pool Math is recommending 24PPM of FC, is this the right place to start? On 05/17 my FC was at 13PPM. By 05/18 I was down to 7PPM. 05/21/23 FC was at 3PPM one gallon of shock was added. 05/22/23 FC measured 5PPM. I’m know I’m eating chlorine and am wondering if that is a significant chlorine loss of 24 hours? I’m just trying to figure out how much liquid I need on hand and am bummed because I’ve since learned I wasted quite a bit of it already.
I know I need to pass an OCLT test and that’s where I have a real problem. I have a neurological sleeping disorder. It is 100% out of the question that I cannot wake up before the sun rises to perform an OCLT. I’m usually up around 12:00, so that is the earliest I could check and I know that’s not good enough. If I were to add chlorine at 18:30 or so, check the level at 19:30 and come back to recheck an OCLT at 02:30 would that yield a good enough test? Any advice would be welcomed! Thank you.
As it stands now:
PH: 7.4
TA: 110
Chlorine: 4
CC: .5
CH: 470
TDS: 1500
Nitrates: 10PPM
Nitrites: 0
