The amount of non-sunlight loss is roughly proportional to the unbound chlorine level so roughly to the FC/CYA ratio. So at the minimum FC/CYA ratio the loss will be less than 1.0 ppm FC and while that means you're likely to pass the OCLT it also means that if you have a smaller but still higher-than-normal chlorine demand you may not measure it reliably at a regular FC/CYA level. The other way to handle this would be to have a smaller OCLT requirement when closer to the minimum FC/CYA ratio, but 0.5 ppm is the error limit when using a 10 ml water sample (and yes, as Dave points out one could use a 25 ml water sample in this case).
Here are the three facts that need to be reconciled for non-sunlight loss measurement:
- Normal loss amount is proportional to the active chlorine level (or possibly the hypochlorite ion level if pH is high and oxidation of CYA is the dominant loss) so roughly related to the FC/CYA ratio.
- Normal loss is temperature dependent roughly doubling every 13ºF.
- Relative test error is (at least) +/- 5% of FC level or +/- 1 drop, whichever is greater.
At a regular non-SLAM FC/CYA ratio, the normal overnight loss should be very small, on the order of less than 0.2 ppm and therefore too low to measure given the accuracy of the FAS-DPD test even using a 25 ml chlorine sample. One can certainly do an OCLT and will be able to detect unusually large losses, but will miss smaller losses.
At a SLAM FC/CYA ratio, the 1 ppm FC criteria is very tight even for accurately measured loss and furthermore the FC level is high enough when the CYA is 50 ppm or more that the error in measurement may exceed this 1 ppm threshold. Instead of using an absolute 1 ppm FC threshold, it would be better to have the criteria vary so at half-SLAM (20% FC/CYA ratio) it would be 1.0 ppm FC, at regular SLAM it would be 1.5 ppm FC, and at yellow/mustard SLAM it would be 3.0 ppm FC. However, the testing error of (at least) 5% of the FC may exceed these numbers when the CYA level is higher so the larger of the two would be used. And yes, this makes this more complicated but would reduce the frustrating "my OCLT keeps varying and I can't consistently pass" problem.
I'm not sure we want to address the temperature dependence and instead use closer to worst-case at somewhat higher temperatures closer to 90ºF (which is my best-guess above) and perhaps note that the OCLT on cold water is not as definitive.
Again, remember the main purpose of the OCLT is to detect unusually high chlorine demand and to know roughly when such demand has been met from elevated chlorine levels. It is a "looser" criteria than seeing visible algae or having cloudy green water. Similarly, having the water be cloudy but not green (especially over days) is not as stringent a criteria either since filtration/circulation is more important for clearing a pool once the algae is all dead.
