I'm in the process of adding my pool pump to my home automation system. The technology I use is called Insteon and they have two options for switches. One is normally open and the other normally closed. Which version would I need?
Bama Rambler said:That's the relay I figured on. While it's not rated for inductive loads it'll probably last a long time running your pump.
