Hello,
I have a pool spa combo. When the pool is in spa mode, the pool pump does not draw water nor does water get pushed out of the spa jets. Pool company came out and pushed air through the pump to the spa and it was clear. I did just have new automation and a new heater installed. Everything worked fine for a few days and then it just started failing. During the heater and automation install the valve actuators were also replaced. There is air coming from somewhere because now when in spa mode I have to release air via the filter.
The pool company thinks it's a damaged pipe since there is a small tree (seemingly) over the line that runs to the spa from the equipment. I am skeptical since it's a mini palm barely four feet high so again the chances of a mini palms roots damaging the pipe seems kind of high.
Please let me know if I can provide any more details at all.
Thanks in advance for any input or guidance.
Adam
Adam
