Hello, yesterday I opened the pool. I went through the same procedure I do every year. When I turned the pump on for the first time, I heard a loud clank noise that sounded like it could have come from the pump. I now have very low pressure coming out of the returns and no suction in the skimmers. However, when I put the multiport valve in the waste position, skimmer suction is fine and water comes out of the hose normal. One thing to note, but I'm not sure this has anything to do with it, I accidentally turned the pump on when all the ball valves to the lines were still closed. I immediately noticed it however and quickly turned the pump off.
Pool is inground salt with Hayward VS pump and Hayward sand filter (just changed the sand). 2 skimmers, 3 returns.
Thank you for any help/ advice!
