No Ground visible in aluminum light niche
Crooked_Pool
17
Florida
Taking a closer look at this light... I had a history of turning off by itself and finally stopped. I picked up a new transformer- 300watt. The bulb is also 300watt....
As you can see it’s an old school Pentair set up. I did locate the ground wire within the cord, but seems like I’ve seen some with a separate ground.
Any thoughts? We’ve not had any issues - just thought I would ask while the pool is empty. Thank you!!
A bonding jumper is required in a nonmetalic conduit unless a listed low-voltage lighting system not requiring grounding is used.
The bonding jumper is a supplemental ground in addition to the ground in the light cord.
Since you have a low voltage light, the bonding jumper should not be required.
The light installation manual should specify if the light requires a ground.
Reactions: Crooked_Pool
